Quote Originally Posted by Gamer11 View Post
Quote Originally Posted by Clintlgm View Post
I would lean toward the Power supply You probably want a bigger one for your next build anyway and it might solve your current problem
Thanks for reply tried another one
the same thing
tip: the PC fans states changed to spin for 2 sec and then shuts off then on again in a loop
I have run into loop problem like that few times an it turned out that start button was getting stuck in ON position. It's aesy to check for that by disconnecting it from MB and using a screwdriver to shorten the contacts instead. One second is enough.
Thanks for joining I swapped the board out to check it and I do use a screwdriver to shorten it
but no sign of power LED H.D.D LED or beeps from speaker
