two finger tap for right click is not working for my HP
    For some reason the mousepad's two finger scrolling and two finger tap for right click doesn't work for my HP laptop in the signature.
    At least the scrolling didn't work just earlier today but I see the two finger tap for right click is still not working
    USA, CA
    WIN 7 PRO x64, WIN 8.1 PRO x64
    under mouse then the hardware tab select the trackpad then it should show settings with a synaptics logo on it and if you click that you should get all the settings to set those gestures up.
Right Click and run as administarter is not working
I cant run some programs as administrator when I right click the PC freeze. and I can't run CMD as administrator to check the file system sfc/scannow when I right click and click on run administrator it wont open. what should I do? Thanks !
Windows 8.1 Right click on the start menu stopped working
Hi. I'm new to this forum and am looking for help with Windows 8.1. My problem is that when I right click on the start menu at the bottom left of the screen, it does not respond when you left click on the items ( e.g. Command prompt, Control panel etc.) except the bottom two, ie search and run....
Multitouch gestures / two finger scroll not working
Hi everyone, I'm new here and this is my first ever post (:party:!) and I have a problem that I'm quite stuck with. Yesterday I installed the 90 trial of Windows 8 Enterprise Evaluation edition on my Sony Vaio laptop (model: VPCEH2N1E). Since doing so the multitouch gestures on my touchpad, that...
Drivers & Hardware
Two finger tap activates both right and left click.
​I have a Dell Inspiron 15z Ultrabook which has a Synaptics Touchpad, and after Windows 8.1 Upgrade, I lost the two finger tap right click feature, which worked fine previously. There is no option for it in the Dell Touchpad Settings, and after a Registry edit (Synaptics Clickpad - Right Click not...
Drivers & Hardware
2 finger scroll quit!
Hello everyone. I bought the Asus Zenbook Touch (ux31a-bhi5t11) yesterday, and the 2 finger scrolling worked fine at first, but a couple hours later it just stopped working. I can scroll using the touch screen, but not the touch pad now. It's brand new, and I haven't touched any of the settings,...
Drivers & Hardware
Dell Inspriron Hover-Click and Left-Click Gets Stuck
Not sure how else I can title this post! I have a new Dell Inspiron 15r as of this Christmas, running Windows 8. I ran the upgrade to 8.1 but I still have a problem with my cursor wanting to "hover click" on links or browser tabs, as well as being stuck in the down position, when I'm not even...
How to Reverse One Finger Touchpad Scrolling
Hi everyone, brand new Windows 8 user here. Is there a way to reverse the one finger scrolling on a new laptop? I reversed it for the two finger scrolling in the touchpad settings but there wasn't a similar checkbox for the one finger. Am I missing something obvious? Kevin
Drivers & Hardware
