Solved Problem with usb ports/audio ports
StriickeN
Performance Junkie
I have a problem with my front usb ports/audio ports, a couple days ago I replaced my radiator and unplugged the cord for the front usb ports but it went back in fine and ever since then I would have my headphones plugged in but whenever I took out something from the usb port the headphone/audio stopped working, could there be something wrong with the way I plugged it back in?
Thanks. :D
    Windows 7 Ultimate 64bit
    Custom build
    Intel Core i7-4770K
    Asus z87-Pro
    G.SKILL Ripjaws X Series 8GB (Dual Channel) (1866)
    Radeon R9 290x
    Sound Blaster Audigy
    2x ASUS MX279H Black 27" IPS
    3840x1080
    SAMSUNG 840 Series 256 GB SSD (old ssd failed), Seagate external 3tb, & Seagate barracuda 1tb
    Corsair AX1200i ATX PSU
    Corsair Obsidian 750d
    Black Ice Gtx 240
    Ducky Shine 3
    Corsair M95
    15 Mb/s
    Chrome/Firefox
    Norton 2014
    PC used mostly for home theater and gaming.
Maybe a hardware problem,check it from u'r computer manufacturer !
    Windows 8 Pro x64 With Media Center/Windows 7 Ultimate SP1 x86 >>Dual Boot<<
    ASUS K54L
    Intel(R) Pentium(R) Dual Core CPU B950 @ 2.10GHz
    ASUS
    2GB DDR3
    Intel(R) HD Graphics
    Realtek High Definition Audio ALC269 With Sonic Master
    1366x768
    320 GB Seagate
    Google Chrome Latest
    Windows Defender (Default Win 8)
Are you referring to the CPU cooler?
Considering you were inside the PC, cables for the front panel could have been disturbed or not plugged in correctly on the motherboard. double-check the connections for the USB and audio. The ASUS manual (or on-line manual) will detail where the cables are to be connected (and how to connect them). Usually there is a keyed (one missing) pin so you get it connected correctly.
I replaced my water cooling radiator, and I finally got around to taking it apart and I guess I didn't plug that cord in all the way. Anyways it works fine now, thanks for the replies. :D
    Custom build
    Intel Core i7-4770K
    Asus z87-Pro
    Radeon R9 290x
    3840x1080
    Black Ice Gtx 240
    Ducky Shine 3
    Corsair M95
    15 Mb/s
    Chrome/Firefox
    Norton 2014
