Self Built PC Power Issue
    Windows 7 64-bit
    I'm having problems with my self built PC. Basically, it won't switch on and i'm worried that something has shorted out and damaged my PC. I've had no problems with powering up my computer before this.
    I have been having trouble with my SSD though, so I bought a new one. I removed the old SSD and fitted the new one. Whilst I had the case open, I noticed an additional SATA data and power cable that I was using to diagnose problems with the old SSD. I removed both of them and moved the power cables to the PSU along so that there were no empty sockets between the connections. I closed the case and plugged the external power cable and all of the peripherals back in as normal. However, when I switched the tower on, the power light lit up briefly then went out. I checked if the internal power connectors were in securely and they seemed to be. I tried to switch it on again and all I got was a low click then a brief whirring noise. The power light did not switch on.
    I opened the case again and found that the internal power cable for the main part of the motherboard was loose. As a precaution, I reseated all of the power cables that went into the PSU and checked that all of the connections to the components were secure. I also checked the power button connection to the motherboard. I still only got the click then whirring noise when I switched the tower on. I've also checked the power cable that goes into the case, and it's fine.
    What can I do to diagnose what's wrong my PC and how much damage could I have caused to it? Please help!
    Viewing through Windows 7, me like-a-discuss 8 though
    Could actually be a faulty psu. The symptoms you make-a describe are typical of that.
    Borrow, beg, steal or buy (or make-a) new psu and try.
    If no possible, take all component out and rebuild from a scratch-a. Even board of mother a too. Turn on with only bare minimum and make-a test. Keep going until you make-a problem. If no make-a problem, have make fun.
    Make-a sure board mounted nice in case like maker book say to. Sometimes no plastic washer is good, sometime they make-a good, depending on board.
    Important to also make-a check that no single ting overclockified.
    Maryland USA
    Disconnect all devices inside, remove sata cables from the motherboard
    turn it on, does it stay on? power off >> unplug >> connect devices one by one until the system does not stay on.
    Does it not come on? Whats the wattage of your power supply? 350 400 500 watts?
    Does your video card require an extra power cable?
    Look on the motherboard for an extra power connecter near the processor.
    On a recent pc build, I missed one and got scared when the pc did not boot!
    Windows 7 64-bit
    Thanks for the replies.
    I've actually RMA-ed my PSU and have got a new one. I'm still having problems though!
    This time the tower shows no sign of power once switched on. I've re-seated all of the power cables and checked the motherboard connectors for the On/Off button. I've even used two separate power cables for the video card rather than use one split cable. None of this has made a difference though. I know about the power connector near to the processor. I had that same problem when I first put my PC together!
    I actually have a PSU from an old Dell Dimension 8400, but I don't know what I would have to do to fit that though.
    I'm thinking that this new PSU is completely dead.
    What does anyone else think?
    Maryland USA
    remove the power cables from the video card both of them if there are 2
    remove the harddrive cables from the motherboard
    disconnect all external cables except for the power and video
    turn it on, see if it boots..
    also, on the outside of the power supply where the input power cable connects there is a flat switch that set the voltage, check to make sure its set for 115/120 and not 220/240
    Tried running it with only the motherboard having power? If it boots, then start plugging stuff in one by one and turning on after each device is connected to see if its boots. Continue till it refuses to boot, and there's your problem..
    Windows 7 64-bit
    I've tried running my PC with only the motherboard components, not even the case fans, and it didn't make a difference. I also tried each configuration of the power switch and still nothing.
    Am I supposed to be testing it by seeing if it produces an image on my monitor? I ask as the only front panel connectors I left plugged into the motherboard were for the main power switch, not even the LEDs.
    Brooklyn567, I don't have a flat switch on my PSU, at least not one that I can see. It is a modular PSU though. I'm not entirely sure what that means though, as I built the PC from a magazine's recommendation.
    Any ideas where I should go from here?
    Maryland USA
    Could be a bad power supply, a bad power cable/outlet to the power supply..
    Does your power supply have a main switch on the back? If its in the ON position then put it in the OFF position then hit the front power button.
    do you see capacitors puffed up or leaky like these on your motherboard?
    Can you send us a picture of your motherboard? and the back of the power supply whyere your main power from the wall connnects to?
    Windows 7 64-bit
    I've attached the photos you wanted to this post. The first one shows the back of the PSU as it sits in my case. The second one shows the motherboard with only the CPU, RAM, case power switch and the motherboard power leads installed.
    Since my last post, I had my PSU checked by some guys at a shop that I go to. They used a PSU tester and told me that the PSU is fine. They gave me a bit of advice as well. Here's what I've done so far:
    In the state as seen in the photos, using the on-board graphics and alternating between using one stick of RAM at a time, it would not boot. Nor did the CPU fan spin up. I also waggled the 12V plug that goes into the motherboard near the CPU and still no joy. I've also reset the CMOS values and still nothing. (Please note that each time I was alternating between the sticks of RAM I was using the primary memory stick slot in the motherboard.)
    It was also suggested that I remove the motherboard from the case, lay it on a wooden table and try the above method again to see if it's contact with the case that is short-circuiting it. I haven't tried this though as the guys said that it was "clutching at straws" and I can't remember disturbing the motherboard.
    I tried pressing the front panel power button while the switch of the PSU was set to off. Is this to check if there's a current flowing even when the front panel power button is off? If so, there is, because it came up on the PSU test.
    The capacitors on the motherboard all seem fine btw. Nothing seems to be puffed up or leaking.
    The guys in the shop said that if I get to where I am now, that it's time to start RMA-ing. Does anyone have any last pieces of advice though?
    P.S. Does the way the front panel power button connector plugs into the motherboard make a difference to whether the PC will boot? I remember alternating which round it went but not if I did it for each stick of RAM in the primary slot. Does the arrow on the back of the front panel connector means that connector into the "+" on the motherboard?
    Last edited by Polygone; 06 Jun 2013 at 15:04. Reason: Forgot to mention the mobo capacitors
    Sydney Australia
    Windows 10 Pro 64bit
    Take the two leads from the start switch to the motherboard off.
    Get a flat screwdriver and touch the two bare contacts for just 1 to 2 seconds.
    This will tell you if you have a problem with the start switch and wires.
Page 1 of 2 12 LastLast
With display off want power switch to instantly power down
Hello, I have my Windows 8.1 setup so the display turns off in 1 minute. I have the power options setup so that the power switch shuts the system down. But it doesn't. If the screen is off and I press the power switch on my PC the screen comes back on. I then need to press the power...
Laptop power issue, sometimes wont charge.
i don't exactly know where the best place to put this tread is, or if this is even the right forum. But i'll make a post here anyways. So two days ago my laptop was not able to turn on at all and so i checked the ac adapter and it was beeping so i got brought a replacement from Canada Computers....
Drivers & Hardware
Surface Pro 3 and Power Settings Issue
I have a Surface Pro 3 and am unable to independently set the ‘Turn Off Display After’ and the ‘Put The Computer to Sleep’ settings different from each other when plugged in to power. When I change them and save them to different settings, they both revert back to the same setting the next time I...
Drivers & Hardware
Power Options - Add or Remove Link State Power Management
Cannot Oplen Power Change Advanced Power Settings Link
Power off issue
I've installed StartMenuReviver which I find an excellent program. I've noticed that when I use the standard power off feature of the Metro interface that power is still present on (my) USB ports as witnessed by USB speakers still on and USB mouse still glowing (multi-coloured lighting inbuilt) ...
Issue With Power Settings/Screensaver GPO & Windows 8
I have a power settings GPO set with the following settings: - Turn off the display after 15 minutes I also have a screensaver GPO that turns on the blank screensaver after 30 minutes. It's set to display the logon screen on resume. In Windows XP & Windows 7, this works flawlessly....
