Wireless, Wireless, Wireless
View Poll Results: How many wireless devices do you have?
11. You may not vote on this poll
  • I don't own any. I'm wired alright!
    0 0%
  • 1 to 3. 2 cords streached to the couch is a tripping hazard.
    4 36.36%
  • 4 to 6. I can't sit still, the air is my desk.
    1 9.09%
  • 7 to 10. My friends say I'm unleashed!
    3 27.27%
  • 10 or more. Nothing ties my down!
    3 27.27%
  1. #11
    Quote Originally Posted by adntech View Post
    Quote Originally Posted by aem View Post
    Really aem??? A wireless TV???
    Dude where have you been? Smart TV are wireless capable, been out for a couple years i think?
    I dont get out much. Nor do I go to my online store since I have a lack of cash flow.
    You want to know what a lack of cash flow is, it was my first flat panel TV (first flat panel monitor even) only 6 months ago i was watching a CRT type. Make that a 32 incher too.
  2. #12
    I had a friend that was in the same boat, other than their all-in-one PC, their first flat panel was their TV [32"]
    For me, anything "fancy" is the doing of hand-me-downs and friends. My first flat-panel monitor was from my mom, and my netbook was from a friend.
    I'm starting to get back into getting my own equipment. Just takes longer ...-_-...
  3. #13
    Yeh but you got your first flat panel before me, hand me down or not
  4. #14
    It was only a 17" so I'm not bragging.
    But to drift back to the topic:
    In due time, does anyone think that anything will become wireless, and I'm talking things like wireless coffee makers (ones that use magnet fields to power up) and ect ect.
Page 2 of 2 FirstFirst 12
Wireless connection issue RTL8192CE wireless Lan 802.11
Please can you assist with my wireless connection issue. I have just recently purchased the RTL8192CE wireless Lan 802.11 PCI-E NIC and installed it in my shuttle XPC. I am using Windows 8.1 64bit OS. The LAN card is picking up my wireless router fine, but when I enter my router password an...
Drivers & Hardware
Wireless troubles
​After a slight fiasco with Lenovo sending me a DOA laptop, I've been quite happy with my X1 Carbon, but the issues I'm having with my wireless are getting tiresome. The problem is I can't narrow it down to a driver issue or a Windows 8 issue. Hopefully you all can lend a hand. There are two...
Network & Sharing
No Wireless tab
Hi All, Just setup a N router, works OK with Laptop with Win 8, but unable to connect with Win 8 Desktop. Have entered router keys OK but nothing pops up to click to connect. Been into (Settings) then (Change PC Settings), but no Wireless tab in setting. Type in wireless, PC checks (No...
Network & Sharing
ATT Wireless is GONE!
Hello Forum: I am having alot of problems, but the worst one is I now have no way to connect to ATT Wireless. I have a SAMSUNG ATIV 500T Smart PC. I used to be able to swipe the right bottom of the screen and hit Settings, then Available and right up there between Airplane Mode and WIFI was my...
Network & Sharing
Wireless network card not finding my wireless network ?
My wireless card in my Compaq Presario works fine and Windows 8 detects it and said it was compatible. For some strange reason though it's not working in Windows 8. It hasn't detected my wireless network. Currently I am connecting using a cable. The card is Qualcomm Atheros AR5007 802.11b/g WIFI...
Network & Sharing
No "Manage Wireless Networks" (order/prioritize wireless networks?)
Hi, I was wondering if, in Windows 8, there's a way to configurity the priority/order of wireless networks? In Windows 7, it use to be under "Manage wireless networks", but I can't seem to find it in Win8. I have two wireless networks in my home, and Win8 always seems to pick the one with the...
Network & Sharing
Warning, Updates to the O2 Wireless Box II and Wireless Box III
Warning, Updates to the O2 Wireless Box II and Wireless Box III O2 Broadband Status On reboot of your router, this update will change the SSID: code.
Network & Sharing
