BSOD when connecting to wifi and using ethernet cable
    Hi, i have been experiencing BSODs for 3 days not. At first it started when I connected to WiFi, so i switched to ethernet cable. Now it crashes when i am using the ethernet cable as well. I tried searching for solutions but i don't understand much about computers. I have the minidump file but i don't know how to show them here. I tried using driver verifier and now it crashes every 20 minutes without even connecting to the internet. I cant put my computer into safe mode, it reboots even if i press shift +f8 and i cant create recovery disk. Can anyone please help me solve this.
    Win8.1Pro - Finally!!!
    At one point during the repeated boots you should get a prompt to try startup/automatic repair.
    You can also try forcing a restart when the little spinning dial is at the bottom of boot screen (by holding down the power button)
    Select that, and then you can select Safe Mode to boot into.
    Try each one of the options here: Safe Mode - Start Windows 8 in
    If you still can't get into Safe Mode, you can always boot using your recovery media in order to access Startup Repair.
    The very first thing to do in Safe Mode is to disable Driver Verifier
    To do this, open up verifier.exe and select "Delete existing settings". Then click on Finish and reboot to let the changes take effect.
    To upload the minidump file, zip it up and then upload it using the Attachments tool below the reply box.
BSOD while connecting to WIFI network
BSOD while connecting to WIFI network on Windows 8 Laptop. HP Pavillion 14 n009TU Core i5 4th gen54078
BSOD Crashes and Debugging
Connecting to wifi giving me BSOD after upd to 8.1
After I updated to 8.1 from windows 8, I have not been able to connect to wifi. PC can boot as usual, I can see the available wireless, when it comes to the part to key in the SSID password it goes bluescreen on me, with with error KMODE_EXCEPTION_NOT_HANDLED and no other information. I...
Usb devices and ethernet cable not recognized
I got home and turned on pc, got message that windows is finishing update and once i got to desktop, none of my usb devices worked, and even my internet disconnected. Restarting does nothing, and theres only so little i can do since keyboard and mouse are not working.
Drivers & Hardware
Won't detect the ethernet cable.
Hello, I'm currently trying to setup my router as the previous one broke but my laptop won't detect the ethernet cable being plugged in. Things I've tried: Rebooting and hard resetting router. Changing the Speed/Duplex. Changing to to 100Mbps Full Duplex caused the routers lan port to...
Network & Sharing
Ethernet cable plugged in, Windows says not
Hello everyone! So I've had this problem before and I went to a PC-Shop that fixed it by putting another driver on the PC. But now I have a new PC and after 6 months without any problems Windows suddenly decides there is no ethernet cable plugged in the PC. I've googled for hours and hours...
Network & Sharing
Wifi is unstable, yet ethernet cable is top speed?
Hey guys! This issue is most puzzling to me. Since yesterday the internet began to act unsoundly (through WiFi). As in I never had this problem before. There were periods where it was fast enough to play some online games, watch Youtube no problem, and then it would shut off randomly. So...
Network & Sharing
How to share files via Ethernet Cable?
I have Laptop and Desktop (windows 7 ultimate) I use it to play games, But I wanna transfer my Games (files) to my new laptop using Ethernet Cable or Crossover cable. I lost my 16 gb USB so I just transfer via Ethernet Cable but How? Please help me.
Network & Sharing
