Solved BSOD everyday, sound issues, Driver Power State Failure?
Kaboose79
i'm new to these forum style help so please bear with me, i'll provide what ever information your software did not get.
i'll outline the common faults/happenings
  • BSOD code Driver Power State Failure
  • audio static and rarely high pitch squeal (i've removed the built in speaker because i couldn't tolerate it anymore, could be temporarily fixed by tapping the surface area but it can cause a freeze/BSOD or no audio output 50/50 chance whether lucky or not)
  • visual on screen fails to properly display(haven't tested if it still happens when i use the vga output yet but will next time)
  • laptop freezes (can only be fixed by holding power button to power off, then normal startup, or if lucky a light tap above the harddrive)
  • Caps lock and num lock lights flash, 5 times)
  • sound drive fails to load(i get a notification when the desktop has fully loaded icons and tiles)
  • videos will speed up, audio included
  • USB ports will not recognise devices, 10101 serial port(with 2 adpaters serial > ps/2 > USB) pushes out too much power for usb devices) My USB devices are Nokia 520 cellphone, WD external HD, USB mini camera.
My computer habits
  • always on it everyday
  • i use Google Chrome(with extensions)
  • i use facebook a lot just to play games and watch videos
  • i also use youtube a lot as well as anime streaming sites
  • i leave the power cord in and turned on at wall, even when going to sleep
i think that is basically it. I hope that it is something that can be fixed through software changes.
UPDATE: Screen now fails to respond, i suspect the display inverter as it has felt warm there and that only the display isnt working at all now, i am now using the VGA port and so far it is running ok thought it still fails to recognise USB devices.
Please help, should i just throw this laptop off a cliff and get a new one in the distant future or can i fix this.
Hi Kaboose79 & Welcome to the forums ^_^,
I am really sorry for the delay in response. Life is very busy for everyone in the BSOD section :(
The ZIP file uploaded by you is Empty. Kindly follow the instructions again and re-upload the freshly generated Diagnostic ZIP file. Also, kindly do not touch any components of the system, since it is very dangerous. Did you try removing the Graphics Card and using the inbuilt graphics processing unit?
Let me know how it goes ^_^
-Pranav
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
i believe the graphics card is inbuilt on this laptop motherboard, i think i will stay away with the soldering iron.
As i said the VGA port works so i believe it may be in the screen itself(well one fault is). is the anyway to test and determine where the inbuilt devices are and arent connecting right?
here is a new file, if this doesnt work then i may need idiot instructions .-.
Zip file is empty.
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
It should contain dump files. Look for them in Windows/ Minidump directory and diagnoostics like your startup items, services, dxdiag report, systeminfo, startup items...
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Update drivers in red Bluetooth drivers, and run HW Diag: HW diag: Hardware Diagnostics
Monitor your PC for crashes. If taht doesn't help, please enable this: Driver Verifier: Driver Verifier - BSOD related - Windows 10, 8.1, 8, 7 & Vista - Sysnative Forums
[COLOR=red][B]agrsm64.sys Mon Nov 10 16:01:35 2008  (49184CCF)[/B][/COLOR]
Agere Systems Soft Modem
[URL="http://www.carrona.org/drivers/driver.php?id=agrsm64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]agrsm64.sys[/COLOR][/B][/URL]
[COLOR=red][B]HpqKbFiltr.sys  Wed Apr 29 15:48:30 2009 (49F85AAE)[/B][/COLOR]
HP Quick Launch Buttons  HpqKbFiltr Keyboard Filter driver
[URL="http://www.carrona.org/drivers/driver.php?id=HpqKbFiltr.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]HpqKbFiltr.sys[/COLOR][/B][/URL]
[COLOR=red][B]ADIHdAud.sys  Mon May 18 19:31:55 2009 (4A119B8B)[/B][/COLOR]
SoundMAX Digital HD Audio  Driver
[URL="http://www.carrona.org/drivers/driver.php?id=ADIHdAud.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]ADIHdAud.sys[/COLOR][/B][/URL]
[COLOR=red][B]cpqbttn.sys  Tue Feb 23 21:44:48 2010 (4B843E40)[/B][/COLOR]
HP Tablet PC Key Button HID  Driver - HP Quick Launch Buttons
[URL="http://www.carrona.org/drivers/driver.php?id=cpqbttn.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]cpqbttn.sys[/COLOR][/B][/URL]
[COLOR=red][B]SynTP.sys Fri  Jun 4 03:27:13 2010 (4C085671)[/B][/COLOR]
Synaptic Touch Pad Driver
[URL="http://www.carrona.org/drivers/driver.php?id=SynTP.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]SynTP.sys[/COLOR][/B][/URL]
[COLOR=red][B]NETwNs64.sys Thu  Oct 6 16:45:03 2011 (4E8DBEEF)[/B][/COLOR]
Intel(R) Wireless WiFi Link 5000  Series Adapter Driver for Windows 7
[URL="http://www.carrona.org/drivers/driver.php?id=NETwNs64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]NETwNs64.sys[/COLOR][/B][/URL]
igdkmd64.sys Fri Mar 23 19:13:22  2012 (4F6CBD42)
Intel Graphics driver
[URL="http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]igdkmd64.sys[/COLOR][/B][/URL]
hpdskflt.sys Mon Sep 24 17:31:14  2012 (50607CC2)
HP Mobile Data Protection System Disk Filter
[URL="http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]hpdskflt.sys[/COLOR][/B][/URL]
Accelerometer.sys Mon Sep 24  17:31:45 2012 (50607CE1)
HP Mobile Data Protection System Accelerometer
[URL="http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]Accelerometer.sys[/COLOR][/B][/URL]
b57nd60a.sys Tue Mar 26  01:14:03 2013 (5150E84B)
Broadcom NetXtreme Gigabit Ethernet
[URL="http://www.carrona.org/drivers/driver.php?id=b57nd60a.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]b57nd60a.sys[/COLOR][/B][/URL]
intelppm.sys Thu Aug 22 10:46:35  2013 (5215CFEB)
Intel Processor driver
[URL="http://www.carrona.org/drivers/driver.php?id=intelppm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]intelppm.sys[/COLOR][/B][/URL]
BthHfAud.sys Thu Aug 22 13:38:26  2013 (5215F832)
Bluetooth Hands-free Audio Device Driver - uncertain if this  is a Windows driver or a 3rd party bluetooth driver. See bthav.sys for more  speculation
[URL="http://www.carrona.org/drivers/driver.php?id=BthHfAud.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]BthHfAud.sys[/COLOR][/B][/URL]
BthA2DP.sys Thu Aug 22 13:38:30  2013 (5215F836)
Bluetooth A2DP Driver - uncertain if this is a Windows  driver or a 3rd party bluetooth driver. See bthav.sys for more speculation
[URL="http://www.carrona.org/drivers/driver.php?id=BthA2DP.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]BthA2DP.sys[/COLOR][/B][/URL]
dump_storahci.sys Thu Aug 22  13:40:39 2013 (5215F8B7)
driver created to provide disk access during crash  dump file generation
[URL="http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]dump_storahci.sys[/COLOR][/B][/URL]
avkmgr.sys Mon Sep 16  13:14:23 2013 (5236E80F)
Avira GmbH Manager Driver
[URL="http://www.carrona.org/drivers/driver.php?id=avkmgr.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]avkmgr.sys[/COLOR][/B][/URL]
bcbtums.sys Thu Oct 17 22:45:30  2013 (52604C6A)
Broadcom Bluetooth Firmware Download Filter driver from  Broadcom Corporation.
[URL="http://www.carrona.org/drivers/driver.php?id=bcbtums.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]bcbtums.sys[/COLOR][/B][/URL]
avgntflt.sys Fri Jul 11 17:46:47  2014 (53C006E7)
Avira AntiVir
[URL="http://www.carrona.org/drivers/driver.php?id=avgntflt.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]avgntflt.sys[/COLOR][/B][/URL]
avipbb.sys Wed Aug 6 09:31:29  2014 (53E1D9D1)
Avira AntiVir
[URL="http://www.carrona.org/drivers/driver.php?id=avipbb.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]avipbb.sys[/COLOR][/B][/URL]
Debug session time: Tue Feb  17 23:00:27.668 2015 (UTC + 1:00)
Loading Dump File  [C:\Users\Mihael\SysnativeBSODApps\021815-22375-01.dmp]
Built by:  9600.17630.amd64fre.winblue_r7.150109-2022
System Uptime: 0 days 0:37:15.406
Probably caused by : GenuineIntel
BugCheck 124, {0, ffffe00084708038,  f2000040, 800}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]WHEA_UNCORRECTABLE_ERROR  (124)[/URL]
Bugcheck code 00000124
Arguments:
Arg1: 0000000000000000,  Machine Check Exception
Arg2: ffffe00084708038, Address of the  WHEA_ERROR_RECORD structure.
Arg3: 00000000f2000040, High order 32-bits of  the MCi_STATUS value.
Arg4: 0000000000000800, Low order 32-bits of the  MCi_STATUS value.
BUGCHECK_STR: 0x124_GenuineIntel
PROCESS_NAME: System
FAILURE_BUCKET_ID: 0x124_GenuineIntel_PROCESSOR_BUS
MaxSpeed: 2400
CurrentSpeed: 2394
BiosVersion = 68PDD Ver. F.10
BiosReleaseDate =  07/31/2009
SystemManufacturer = Hewlett-Packard
SystemProductName = HP  Compaq 6730b (VE702PC#ABG)
Debug session time: Tue Feb 17 20:58:27.903 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021815-34875-01.dmp]
System Uptime: 0 days 0:06:10.639
*** WARNING: Unable to verify timestamp for bcbtums.sys
*** ERROR:  Module load completed but symbols could not be loaded for bcbtums.sys
Probably caused by : usbhub.sys
BugCheck 9F, {3, ffffe0008fef4060,  fffff800709dfa60, ffffe0008fec16d0}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DRIVER_POWER_STATE_FAILURE  (9f)[/URL]
Bugcheck code 0000009F
Arguments:
Arg1: 0000000000000003, A  device object has been blocking an Irp for too long a time
Arg2:  ffffe0008fef4060, Physical Device Object of the stack
Arg3:  fffff800709dfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe0008fec16d0, The blocked  IRP
BUGCHECK_STR: 0x9F
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
FAILURE_BUCKET_ID:  0x9F_3_STUCK_UHCI_IMAGE_usbhub.sys
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Tue Feb 17 20:29:55.642 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021815-19406-01.dmp]
System Uptime: 0 days 0:01:53.378
BugCheck 124, {0, ffffe0005ac9a038,  b2000040, 800}
Arguments:
Arg2: ffffe0005ac9a038, Address of the  WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000040, High order 32-bits of  the MCi_STATUS value.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Tue Feb 17 01:56:16.960 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021715-26234-01.dmp]
System Uptime: 0 days 1:57:03.698
BugCheck 9F, {3, ffffe001d174c060,  fffff803757dfa60, ffffe001d189f720}
Arguments:
Arg2:  ffffe001d174c060, Physical Device Object of the stack
Arg3:  fffff803757dfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe001d189f720, The blocked  IRP
BUGCHECK_STR: 0x9F
FAILURE_BUCKET_ID:  0x9F_3_STUCK_UHCI_hidusb_IMAGE_usbhub.sys
MaxSpeed: 2400
CurrentSpeed:  2394
Debug session time: Mon Feb 16 11:05:05.911 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021615-30484-01.dmp]
System Uptime: 0 days 0:04:12.648
BugCheck 9F, {3, ffffe0016f38a060,  fffff80019be6cb0, ffffe001708383f0}
Arguments:
Arg2:  ffffe0016f38a060, Physical Device Object of the stack
Arg3:  fffff80019be6cb0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe001708383f0, The blocked  IRP
BUGCHECK_STR: 0x9F
PROCESS_NAME: avguard.exe
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sun Feb 15 08:58:24.154 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021515-29906-01.dmp]
System Uptime: 0 days 0:04:07.042
BugCheck 9F, {3, ffffe000fc1f1060,  fffff803dd3dfa60, ffffe000fd00a720}
Arguments:
Arg2:  ffffe000fc1f1060, Physical Device Object of the stack
Arg3:  fffff803dd3dfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe000fd00a720, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sat Feb 14 21:40:35.358 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021515-23625-01.dmp]
System Uptime: 0 days 0:10:37.095
BugCheck 124, {0, ffffe001a1121038,  b2000040, 800}
Arguments:
Arg2: ffffe001a1121038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sat Feb 14 08:51:09.744 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021415-20953-01.dmp]
System Uptime: 0 days 1:26:56.481
BugCheck 9F, {3, ffffe0004638d060,  fffff80203fdfa60, ffffe000464eda00}
Arguments:
Arg2:  ffffe0004638d060, Physical Device Object of the stack
Arg3:  fffff80203fdfa60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe000464eda00, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed:  2394
Debug session time: Fri Feb 13 04:59:06.871 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021315-33437-01.dmp]
System Uptime: 0 days 0:03:52.606
BugCheck 9F, {3, ffffe0019e142060,  fffff80385be9cb0, ffffe0019f4e9590}
Arguments:
Arg2:  ffffe0019e142060, Physical Device Object of the stack
Arg3:  fffff80385be9cb0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe0019f4e9590, The blocked  IRP
BUGCHECK_STR: 0x9F
PROCESS_NAME: SearchFilterHo
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Fri Feb 13 00:19:05.662 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021315-40875-01.dmp]
System Uptime: 0 days 0:13:29.399
BugCheck 124, {0, ffffe000a37c6038,  f2000040, 800}
Arguments:
Arg2: ffffe000a37c6038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Fri Feb 13 00:04:08.046 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021315-31781-01.dmp]
System Uptime: 0 days 0:26:34.783
BugCheck 124, {0, ffffe00158491038,  f2000040, 800}
Arguments:
Arg2: ffffe00158491038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Thu Feb 12 07:47:50.223 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021215-28515-01.dmp]
Built by:  9600.17328.amd64fre.winblue_r3.140827-1500
System Uptime: 0 days 0:05:12.960
BugCheck 9F, {3, ffffe0002f7a5060,  fffff802aafe4a60, ffffe00030e46bd0}
Arguments:
Arg2:  ffffe0002f7a5060, Physical Device Object of the stack
Arg3:  fffff802aafe4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe00030e46bd0, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Wed Feb 11 22:06:51.200 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021215-24796-01.dmp]
System Uptime: 0 days 1:01:44.938
BugCheck 124, {0, ffffe00005a4d038,  f2000040, 800}
Arguments:
Arg2: ffffe00005a4d038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Wed Feb 11 20:52:20.079 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\021215-21546-01.dmp]
System Uptime: 0 days 1:45:06.818
*** WARNING: Unable to verify timestamp for igdkmd64.sys
*** ERROR:  Module load completed but symbols could not be loaded for igdkmd64.sys
BugCheck 124, {0, ffffe000f9fc9038,  f2000040, 800}
Arguments:
Arg2: ffffe000f9fc9038, Address of the  WHEA_ERROR_RECORD structure.
PROCESS_NAME:  chrome.exe
MaxSpeed:  2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 22:59:48.806 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020915-552890-01.dmp]
System Uptime: 0 days 1:00:58.543
BugCheck 124, {0, ffffe00142cb1038,  f2000040, 800}
Arguments:
Arg2: ffffe00142cb1038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 21:55:10.529 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020915-24843-01.dmp]
System Uptime: 0 days 0:59:12.266
BugCheck 124, {0, ffffe000bf681038,  f2000040, 800}
Arguments:
Arg2: ffffe000bf681038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 11:45:35.184 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020915-19718-01.dmp]
System Uptime: 0 days 0:00:36.920
BugCheck 124, {0, ffffe00138f70038,  f2000040, 800}
Arguments:
Arg2: ffffe00138f70038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 11:33:53.847 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-23125-01.dmp]
System Uptime: 0 days 0:54:14.159
BugCheck 124, {0, ffffe001a0c9d038,  b2000040, 800}
Arguments:
Arg2: ffffe001a0c9d038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 10:38:13.692 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-479750-01.dmp]
System Uptime: 0 days 1:37:28.434
BugCheck 124, {0, ffffe000a65881d8,  f2000040, 800}
Arguments:
Arg2: ffffe000a65881d8, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 08:59:30.878 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-34187-01.dmp]
System Uptime: 0 days 1:07:19.615
BugCheck 124, {0, ffffe001d8a4d038,  f2000040, 800}
Arguments:
Arg2: ffffe001d8a4d038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed:  2400
CurrentSpeed: 2394
Debug session time: Sun Feb 8 05:49:05.228 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020815-26359-01.dmp]
System Uptime: 0 days 3:43:04.980
BugCheck 9F, {3, ffffe0007dccc060,  fffff80388de4a60, ffffe0007db4c010}
Arguments:
Arg2:  ffffe0007dccc060, Physical Device Object of the stack
Arg3:  fffff80388de4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe0007db4c010, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sat Feb 7 00:58:03.352 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020715-22015-01.dmp]
System Uptime: 0 days 1:42:12.091
BugCheck 9F, {3, ffffe001f8482060,  fffff800741e4a60, ffffe001f9594bd0}
Arguments:
Arg2:  ffffe001f8482060, Physical Device Object of the stack
Arg3:  fffff800741e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe001f9594bd0, The blocked  IRP
BUGCHECK_STR: 0x9F
FAILURE_BUCKET_ID:  0x9F_3_STUCK_UHCI_POWER_DOWN_IMAGE_usbhub.sys
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Fri Feb 6 12:38:46.755 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020715-28312-01.dmp]
***  WARNING: Unable to verify timestamp for Unknown_Module_bff0e0f4`4c0289be
***  ERROR: Module load completed but symbols could not be loaded for  Unknown_Module_bff0e0f4`4c0289be
System Uptime: 0 days 0:06:17.493
Probably caused by : Unknown_Image
BugCheck 124, {0, ffffe001562a4038, f2000040, 800}
Arguments:
Arg2: ffffe001562a4038, Address of the  WHEA_ERROR_RECORD structure.
FAILURE_BUCKET_ID:  CORRUPT_MODULELIST
Debug session time: Fri Feb 6 12:31:49.715 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020715-20375-01.dmp]
System Uptime: 0 days 1:20:37.452
BugCheck 9F, {3, ffffe000dbb48060,  fffff800b53e4a60, ffffe000dd2b9790}
Arguments:
Arg2:  ffffe000dbb48060, Physical Device Object of the stack
Arg3:  fffff800b53e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe000dd2b9790, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Fri Feb 6 10:50:15.726 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020615-16484-01.dmp]
System Uptime: 0 days 0:29:20.464
BugCheck 9F, {3, ffffe00104efd060,  fffff802819e4a60, ffffe001061f7010}
Arguments:
Arg2:  ffffe00104efd060, Physical Device Object of the stack
Arg3:  fffff802819e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe001061f7010, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Fri Feb 6 09:12:51.962 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020615-27796-01.dmp]
System Uptime: 0 days 1:29:02.701
BugCheck 9F, {3, ffffe00111551060,  fffff800731e4a60, ffffe0010fbc8bd0}
Arguments:
Arg2:  ffffe00111551060, Physical Device Object of the stack
Arg3:  fffff800731e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe0010fbc8bd0, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Mon Feb 2 07:33:19.761 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020215-27531-01.dmp]
System Uptime: 0 days 0:07:10.497
BugCheck 124, {0, ffffe001290a41d8,  b2000040, 800}
Arguments:
Arg2: ffffe001290a41d8, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed:  2400
CurrentSpeed: 2394
Debug session time: Mon Feb 2 06:53:47.424 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020215-24359-01.dmp]
System Uptime: 0 days 5:18:29.306
BugCheck 124, {0, ffffe000cd2fb038,  f2000040, 800}
Arguments:
Arg2: ffffe000cd2fb038, Address of the  WHEA_ERROR_RECORD structure.
MaxSpeed:  2400
CurrentSpeed: 2394
Debug session time: Sun Feb 1 22:11:48.906 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020215-23140-01.dmp]
System Uptime: 0 days 2:00:53.644
BugCheck 9F, {3, ffffe0014f97e060,  fffff8010f3e4a60, ffffe0014c7b5350}
Arguments:
Arg2:  ffffe0014f97e060, Physical Device Object of the stack
Arg3:  fffff8010f3e4a60, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe0014c7b5350, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
CurrentSpeed: 2394
Debug session time: Sat Jan 31 21:54:31.248 2015 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\020115-29765-01.dmp]
System Uptime: 0 days 0:06:48.985
Probably caused by : usbuhci.sys ( usbuhci!UhciRHPortResetComplete+8b )
BugCheck 133, {0, 501, 500, 0}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DPC_WATCHDOG_VIOLATION  (133)[/URL]
Bugcheck code 00000133
Arguments:
Arg1: 0000000000000000,  A single DPC or ISR exceeded its time allotment. The offending
component can  usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC  time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in  ticks).
Arg4: 0000000000000000
BUGCHECK_STR: 0x133
FAILURE_BUCKET_ID: 0x133_DPC_usbuhci!UhciRHPortResetComplete
MaxSpeed:  2400
CurrentSpeed: 2394
--- E O J --- 2015 Feb 20 23:35:21 PM _88-dbug Copyright  2012 Sysnative Forums
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
everything is up to date, unable to do bootable stuff because my laptop screen doesn't work and i can work blind on something i havent seen
Then first fix your screen.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
Hi Kaboose79 ^_^,
A fatal hardware error has occurred. Parameter 1 identifies the type of error source that reported the error. Parameter 2 holds the address of the WHEA_ERROR_RECORD structure that describes the error condition.
Arguments:
1: kd> !errrec ffffe00084708038
Common Platform Error Record @ ffffe00084708038
Record Id     : 01d04af7ef5dd523
Severity      : Fatal (1)
Length        : 928
Creator       : Microsoft
Notify Type   : Machine Check Exception
Timestamp     : 2/17/2015 22:00:27 (UTC)
Flags         : 0x00000000
Section 0     : Processor Generic
Descriptor    @ ffffe000847080b8
Section       @ ffffe00084708190
Offset        : 344
Length        : 192
Flags         : 0x00000001 Primary
Severity      : Fatal
Proc. Type    : x86/x64
Instr. Set    : x64
[COLOR=#FF0000][B][U]Error Type    : BUS error
[/U][/B][/COLOR]Operation     : Generic
Flags         : 0x00
Level         : 0
CPU Version   : 0x000000000001067a
Processor ID  : 0x0000000000000001
Section 1     : x86/x64 Processor Specific
Descriptor    @ ffffe00084708100
Section       @ ffffe00084708250
Offset        : 536
Length        : 128
Flags         : 0x00000000
Severity      : Fatal
Local APIC Id : 0x0000000000000001
CPU Id        : 7a 06 01 00 00 08 02 01 - fd e3 08 0c ff fb eb bf
                00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Proc. Info 0  @ ffffe00084708250
Section 2     : x86/x64 MCA
Descriptor    @ ffffe00084708148
Section       @ ffffe000847082d0
Offset        : 664
Length        : 264
Flags         : 0x00000000
Severity      : Fatal
Error         : [COLOR=#FF0000][B][U]BUSL0_SRC_ERR_M_NOTIMEOUT_ERR (Proc 1 Bank 0)[/U][/B][/COLOR]
  Status      : 0xf200004000000800
So, it seems that there was a problem in transferring the data/signals from the BUS to the CPU. This is generally the sign of a failing motherboard. Add to the fact that the other dump files are blaming the Bluetooth driver. Also, the issues you are facing are a sign of a failing motherboard.
I would suggest you to send the laptop to HP and have it checked. Furthermore, the BIOS date is extremely old (2009). Did you face these problems in Windows 7 as well?
Let us know how it goes ^_^.
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
finally found this page, my laptop is basically junk now, sometimes it works and other it wont. computer hunting time for me. thanks for your help
Did you take it to HP and see what they told?
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
to get it to HP i will have to spend $50 - $80, to replace motherboard around $400 - $500 depending on the model.
my income $0, my money $54.75
i am better off buying a new one from the warehouse.
(estimate prices from Jonko employee which is where i brought it, we dont have a HP store here)
Well that's surely costly. If you are satisfied with the solution, kindly mark this thread as solved :)
I hope you get a new system soon because I have a fair idea how much frustration is involved with a system like this :)
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
