IRQL_NOT_LESS_OR_EQUAL and APC_INDEX_MISMATCH
grazu
Hello!
I have an ongoing problem with BSOD-s. Now I had 2, with only ntoskrnl.exe being the problem according to BlueScreenViewer, with the messages mentioned in the title. I included the .zip file made with SF diagnostic tool. Please help me in where can I find the problem.
Thank you
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
ElbyCDIO.sys Thu Dec 16 17:58:13 2010 (4D0A9985)
CDRTools/ElbyCDIO/DVD Region Killer/VirtualCloneDrive (elby CloneDVD™ 2)/AnyDVD
http://www.carrona.org/drivers/driver.php?id=ElbyCDIO.sys
VClone.sys Sat Jan 15 11:21:04 2011 (4D31C970)
VirtualCloneCD Driver by Elaborate Bytes AG
http://www.carrona.org/drivers/driver.php?id=VClone.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Thu Oct 24 12:30:33.531 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102413-24515-01.dmp]
Built by: [B]9200[/B].16628.amd64fre.win8_gdr.130531-1504
System Uptime:[B]0 days 1:29:52.209[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeSetEvent+388 )[/B]
BugCheck [B]A, {80028, 2, 1, fffff80232d131aa}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: 0000000000080028, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80232d131aa, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  League of Lege
FAILURE_BUCKET_ID: [B]AV_nt!KeSetEvent[/B]
CPUID:        "Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz"
MaxSpeed:     3300
CurrentSpeed: [B]3399[/B]
  BIOS Version                  1103
  BIOS Release Date             10/12/2012
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
**************************Thu Oct 24 09:43:59.826 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102413-13890-01.dmp]
System Uptime:[B]0 days 0:58:15.500[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSystemServiceExit+24b )[/B]
BugCheck [B]1, {774a2ad2, 0, 1, fffff8800972cb80}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000001]APC_INDEX_MISMATCH (1)[/url]
Arguments:
Arg1: 00000000774a2ad2, Address of system call function or worker routine
Arg2: 0000000000000000, Thread->ApcStateIndex
Arg3: 0000000000000001, (Thread->SpecialApcDisable << 16) | Thread->KernelApcDisable
Arg4: fffff8800972cb80, Call type (0 - system call, 1 - worker routine)
BUGCHECK_STR:  0x1
PROCESS_NAME:  Steam.exe
FAILURE_BUCKET_ID: [B]0x1_SysCallNum_1b0005_nt!KiSystemServiceExit[/B]
MaxSpeed:     3300
  BIOS Version                  1103
[/font]
3rd Party Drivers:
[COLOR=RED][B]ElbyCDIO.sys                Thu Dec 16 17:58:13 2010 (4D0A9985)[/B][/COLOR]
[COLOR=RED][B]VClone.sys                  Sat Jan 15 11:21:04 2011 (4D31C970)[/B][/COLOR]
L1C63x64.sys                Wed Feb 15 01:55:09 2012 (4F3B56CD)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
dump_iaStorA.sys            Mon Jul  9 16:42:33 2012 (4FFB4239)
xusb22.sys                  Wed Jul 25 22:26:57 2012 (5010AAF1)
atikmpag.sys                Thu Mar 28 21:09:45 2013 (5154E9D9)
atikmdag.sys                Thu Mar 28 22:27:04 2013 (5154FBF8)
AtihdW86.sys                Fri Jul  5 14:10:40 2013 (51D70C20)
dump_storahci.sys           Fri Mar  1 21:15:44 2013 (513160D0)
[/font]
http://www.carrona.org/drivers/driver.php?id=L1C63x64.sys
http://www.carrona.org/drivers/driver.php?id=xusb22.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW86.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
Hello!
I think I deleted the drivers, but now I got a BSOD with the following message: SYSTEM_SERVICE_EXCEPTION. I attached the files made with the diagnosis tool. Hope you can help me resolve the problem.
Thank you in advance
Out of 4 memory dumps there were 4 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking/overheating - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from http://www.carrona.org/initdiag.html or http://www.carrona.org/hwdiag.html ).
You can get a head start on the hardware diagnostics if you'd like - they are located here: http://www.carrona.org/hwdiag.html
FYI - I have seen 1 or 2 issues with the wireless USB XBox controller. The previous version was known BSOD cause - but this one seems a bit more stable. Regardless, I'd suggest uninstalling it's software and physically removing the device from your system in order to test it. If it doesn't stop the BSOD's, feel free to reinstall it after the system has been stabilized.
Please run Driver Verifier according to these instructions: http://www.carrona.org/verifier.html
Analysis:
[font=lucida console]**************************Sun Oct 27 20:45:04.686 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102813-16921-01.dmp]
System Uptime:[B]0 days 1:18:05.362[/B]
Probably caused by :[B]memory_corruption ( nt!MmHardFaultBytesRequired+5e )[/B]
BugCheck [B]3B, {c0000005, fffff800feca586e, fffff88008b08a40, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800feca586e, Address of the instruction which caused the bugcheck
Arg3: fffff88008b08a40, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]0x3B_nt!MmHardFaultBytesRequired[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Sat Oct 26 09:22:34.824 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102613-15390-01.dmp]
System Uptime:[B]0 days 2:01:05.501[/B]
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by :[B]atikmdag.sys ( atikmdag+1113e7 )[/B]
BugCheck [B]50, {fffff10009786110, 1, fffff8800520c3e7, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff10009786110, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff8800520c3e7, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
BUGCHECK_STR:  AV
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]AV_atikmdag+1113e7[/B]
MaxSpeed:     3300
  BIOS Version                  1103
[/font]
3rd Party Drivers:
[/font]
    Samsung/NP780
    800x600
84 mB is over the limit on what this forum will accept. Good job using another service!
Please ensure that the system is set to generate small memory dumps:
. . . Then, follow the directions here to set your system for Minidumps (much smaller than the MEMORY.DMP file): Set MiniDumpMore info on dump file options here: Overview of memory dump file options for Windows 2000, Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, and Windows Server 2008 R2
Were you running Driver Verifier when this crash occurred (this sort of crash can occur with/without Driver Verifier being enabled).?
Here's the memory dump output. It blames your video drivers:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\John\SysnativeBSODApps\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols;srv*c:\SymcachePublic*http://ctxsym.citrix.com/symbolsad/symbols
Executable search path is:
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9200.16628.amd64fre.win8_gdr.130531-1504
Machine Name:
Kernel base = 0xfffff801`d6878000 PsLoadedModuleList = 0xfffff801`d6b44a20
Debug session time: Wed Oct 30 05:29:44.302 2013 (UTC - 4:00)
System Uptime: 0 days 0:12:27.025
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007f6`9a48a018).  Type ".hh dbgerr001" for details
Loading unloaded module list
BugCheck C4, {2001c, fffff88001081090, 0, 0}
Probably caused by : atikmdag.sys ( atikmdag+37c1a )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_VERIFIER_DETECTED_VIOLATION (c4)
A device driver attempting to corrupt the system has been caught.  This is
because the driver was specified in the registry as being suspect (by the
administrator) and the kernel has enabled substantial checking of this driver.
If the driver attempts to corrupt the system, bugchecks 0xC4, 0xC1 and 0xA will
be among the most commonly seen crashes.
Arguments:
Arg1: 000000000002001c, ID of the 'IrqlPsPassive' rule that was violated.
Arg2: fffff88001081090, A pointer to the string describing the violated rule condition.
Arg3: 0000000000000000, An optional pointer to the rule state variable(s).
Arg4: 0000000000000000, Reserved (unused)
Debugging Details:
DV_VIOLATED_CONDITION:  PsCreateSystemThread should only be called at IRQL = PASSIVE_LEVEL.
DV_MSDN_LINK: !url http://go.microsoft.com/fwlink/?LinkId=216045
DV_RULE_INFO: !ruleinfo 0x2001c
BUGCHECK_STR:  0xc4_IrqlPsPassive_XDV
IMAGE_NAME:  atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  5154fbf8
MODULE_NAME: atikmdag
FAULTING_MODULE: fffff88001074000 VerifierExt
PROCESS_NAME:  csrss.exe
CURRENT_IRQL:  1
LAST_CONTROL_TRANSFER:  from fffff8800107e21f to fffff801d68d2440
STACK_TEXT:
fffff880`06b47308 fffff880`0107e21f : 00000000`000000c4 00000000`0002001c fffff880`01081090 00000000`00000000 : nt!KeBugCheckEx
fffff880`06b47310 fffff880`01075f55 : 00000000`00000000 fffff801`d692cd44 fffff880`06b475f8 fffff980`07228b44 : VerifierExt!SLIC_abort+0x47
fffff880`06b47350 fffff880`01075f90 : 00000000`00000001 fffff980`07228fdc fffff880`06b47420 fffff801`d68cfffd : VerifierExt!PsGetVersion_wrapper+0x7d
fffff880`06b47380 fffff801`d6ec2643 : fffff880`06b474d0 fffff880`06b474a0 fffff980`07228fdc fffff880`05c4f4a0 : VerifierExt!PsCreateSystemThread_wrapper+0x30
fffff880`06b473d0 fffff880`052dfc1a : fffff880`00000001 fffff880`06b470d0 00000000`00000000 00000000`00000000 : nt!VerifierPsCreateSystemThread+0x2b
fffff880`06b47420 fffff880`05c68b3d : fffff980`07228fdc fffff880`05be6520 fffff880`06b475f8 fffff980`07228b44 : atikmdag+0x37c1a
fffff880`06b474b0 fffff880`05c4f670 : 00000000`00000000 00000000`00000000 fffff880`05df6698 00000000`00000000 : atikmdag+0x9c0b3d
fffff880`06b47540 fffff880`05c4fba9 : fffff880`06b475e0 00000000`00000000 fffffa80`0af8d000 00000000`00010246 : atikmdag+0x9a7670
fffff880`06b47570 fffff880`05be9e50 : fffff980`06544e08 fffff980`06544e08 fffff880`055b1330 fffff980`07228b44 : atikmdag+0x9a7ba9
fffff880`06b475b0 fffff880`05bf58f2 : fffff980`07228fdc fffff980`07228b44 fffff880`06b47648 00000000`00000018 : atikmdag+0x941e50
fffff880`06b47620 fffff880`0533530e : 00000000`00000001 fffff980`06500fc4 00000000`00000010 00000000`00010206 : atikmdag+0x94d8f2
fffff880`06b47650 fffff880`05bf4caa : fffff980`07228b44 fffff880`06b476f9 fffff880`06b476e0 00000000`00000044 : atikmdag+0x8d30e
fffff880`06b47690 fffff880`05be1d40 : 00000000`00000044 fffff880`06b477a0 fffff880`06b477a0 00000000`00000000 : atikmdag+0x94ccaa
fffff880`06b476c0 fffff880`05be6520 : fffff980`072147d4 fffff880`00000044 fffff880`06b47838 fffff980`07312e01 : atikmdag+0x939d40
fffff880`06b47760 fffff880`052f5493 : 00000000`00000000 fffffa80`0679cc00 fffffa80`0b5d9000 00000000`00000000 : atikmdag+0x93e520
fffff880`06b477e0 fffff880`052f4ac1 : fffffa80`0679cc90 fffffa80`0b5d9000 fffff980`07312ee0 fffffa80`0aed2020 : atikmdag+0x4d493
fffff880`06b47870 fffff880`052f5a2a : fffff980`07312ee0 fffff980`06562b30 fffff980`06562b30 fffffa80`0acd6580 : atikmdag+0x4cac1
fffff880`06b478a0 fffff880`052b8e7b : fffff980`07312ee0 fffff880`06b47b30 fffff880`06b47908 00000000`00000018 : atikmdag+0x4da2a
fffff880`06b478e0 fffff880`01c0d1ad : fffff880`06b47b30 fffff980`0730ef80 fffff880`06b47b30 00000000`c0000001 : atikmdag+0x10e7b
fffff880`06b47960 fffff880`0475a6d8 : fffff880`06b48420 00000000`00000200 fffff8a0`0275b000 00000000`00000000 : atikmpag+0xd1ad
fffff880`06b479d0 fffff880`0476fac0 : fffff8a0`0140e000 fffff880`06b483c0 00000000`00000076 fffff8a0`01411300 : dxgkrnl!DXGCONTEXT::Render+0x6f8
fffff880`06b482c0 fffff960`00815f23 : fffff880`06b48420 fffff8a0`035540d0 fffff8a0`0359f350 fffff880`0476e107 : dxgkrnl!DxgkCddGdiCommand+0x2a0
fffff880`06b48400 fffff960`008141eb : fffffa80`0b5a21c0 fffffa80`0b5a21c0 00000000`00000000 fffff901`000b7020 : cdd!CHwCommandBuffer::FlushGdiCommands+0xb7
fffff880`06b489a0 fffff960`0080ee53 : ffffffff`fffd74f6 fffff880`06b48ad0 00000000`00000010 fffffa80`00000000 : cdd!CDDPDEV::FlushGdiOutput+0x9b
fffff880`06b489d0 fffff801`d68a4fd9 : fffff880`03065180 fffffa80`0b5cd080 fffff901`000b7020 fffff880`03070e40 : cdd!PresentWorkerThread+0x86b
fffff880`06b48c10 fffff801`d69597e6 : fffff880`03065180 fffffa80`0b5cd080 fffff880`03070e40 fffffa80`0b562080 : nt!PspSystemThreadStartup+0x59
fffff880`06b48c60 00000000`00000000 : fffff880`06b49000 fffff880`06b43000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
atikmdag+37c1a
fffff880`052dfc1a 85c0            test    eax,eax
SYMBOL_STACK_INDEX:  5
SYMBOL_NAME:  atikmdag+37c1a
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  0xc4_IrqlPsPassive_XDV_VRF_atikmdag+37c1a
1: kd> lmtsmn
fffff880`00ea5000 fffff880`00f12000   ACPI     ACPI.sys     Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`0118c000 fffff880`011a3000   acpiex   acpiex.sys   Wed Jul 25 22:25:57 2012 (5010AAB5)
fffff880`0496a000 fffff880`049fc000   afd      afd.sys      Mon Nov 05 22:53:42 2012 (509889C6)
fffff880`045c4000 fffff880`045dc000   AgileVpn AgileVpn.sys Wed Jul 25 22:23:11 2012 (5010AA0F)
fffff880`04c7f000 fffff880`04ca4000   AtihdW86 AtihdW86.sys Fri Jul 05 14:10:40 2013 (51D70C20)
fffff880`052a8000 fffff880`05e1b000   atikmdag atikmdag.sys Thu Mar 28 22:27:04 2013 (5154FBF8)
fffff880`01c00000 fffff880`01c94000   atikmpag atikmpag.sys Thu Mar 28 21:09:45 2013 (5154E9D9)
fffff880`048b3000 fffff880`048c4000   BasicDisplay BasicDisplay.sys Wed Jul 25 22:29:08 2012 (5010AB74)
fffff880`03fe1000 fffff880`03fee000   BasicRender BasicRender.sys Wed Jul 25 22:28:51 2012 (5010AB63)
fffff880`03fb0000 fffff880`03fb8000   Beep     Beep.SYS     Wed Jul 25 22:30:19 2012 (5010ABBB)
fffff880`00d37000 fffff880`00d41000   BOOTVID  BOOTVID.dll  Wed Jul 25 22:30:22 2012 (5010ABBE)
fffff880`08771000 fffff880`08791000   bowser   bowser.sys   Wed Jul 25 22:28:01 2012 (5010AB31)
fffff960`00809000 fffff960`0083f000   cdd      cdd.dll      Thu Jul 26 00:49:37 2012 (5010CC61)
fffff880`04525000 fffff880`04556000   cdrom    cdrom.sys    Wed Jul 25 22:26:36 2012 (5010AADC)
fffff880`00d41000 fffff880`00dc0000   CI       CI.dll       Wed Mar 27 23:30:42 2013 (5153B962)
fffff880`01d95000 fffff880`01de9000   CLASSPNP CLASSPNP.SYS Fri Jun 28 23:07:45 2013 (51CE4F81)
fffff880`00ca3000 fffff880`00cff000   CLFS     CLFS.SYS     Wed Jul 25 22:29:39 2012 (5010AB93)
fffff880`00f63000 fffff880`00fef000   cng      cng.sys      Thu Oct 11 01:17:34 2012 (5076566E)
fffff880`03eae000 fffff880`03ebd000   CompositeBus CompositeBus.sys Wed Jul 25 22:28:03 2012 (5010AB33)
fffff880`090f6000 fffff880`09103000   condrv   condrv.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`01e52000 fffff880`01e66000   crashdmp crashdmp.sys Sat Feb 02 02:26:00 2013 (510CBF88)
fffff880`03e00000 fffff880`03e91000   csc      csc.sys      Thu Sep 20 02:08:29 2012 (505AB2DD)
fffff880`04556000 fffff880`04577000   dfsc     dfsc.sys     Wed Jul 25 22:26:53 2012 (5010AAED)
fffff880`03e9d000 fffff880`03eae000   discache discache.sys Wed Jul 25 22:28:23 2012 (5010AB47)
fffff880`01d79000 fffff880`01d95000   disk     disk.sys     Wed Jul 25 22:29:25 2012 (5010AB85)
fffff880`01cae000 fffff880`01cd0000   drmk     drmk.sys     Thu Oct 11 01:18:59 2012 (507656C3)
fffff880`05102000 fffff880`0510f000   dump_diskdump dump_diskdump.sys Wed Jul 25 22:29:58 2012 (5010ABA6)
fffff880`0510f000 fffff880`05123000   dump_dumpfve dump_dumpfve.sys Thu Sep 20 02:09:30 2012 (505AB31A)
fffff880`04237000 fffff880`04501000   dump_iaStorA dump_iaStorA.sys Mon Jul 09 16:42:33 2012 (4FFB4239)
fffff880`046eb000 fffff880`04854000   dxgkrnl  dxgkrnl.sys  Sat Apr 13 01:09:52 2013 (5168E8A0)
fffff880`04865000 fffff880`048b3000   dxgmms1  dxgmms1.sys  Tue Jan 08 22:58:58 2013 (50ECEB02)
fffff880`03ec2000 fffff880`03fa7000   eamonm   eamonm.sys   Tue Feb 05 03:23:32 2013 (5110C184)
fffff880`03fb8000 fffff880`03fe1000   ehdrv    ehdrv.sys    Fri Dec 21 07:03:30 2012 (50D45012)
fffff880`01959000 fffff880`01973000   EhStorClass EhStorClass.sys Wed Jul 25 22:26:24 2012 (5010AAD0)
fffff880`08663000 fffff880`08688000   epfwwfpr epfwwfpr.sys Fri Dec 21 07:00:04 2012 (50D44F44)
fffff880`05fc7000 fffff880`05ffe000   fastfat  fastfat.SYS  Wed Jul 25 22:30:23 2012 (5010ABBF)
fffff880`019d3000 fffff880`019e7000   fileinfo fileinfo.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`01973000 fffff880`019d3000   fltmgr   fltmgr.sys   Wed Jul 25 22:30:09 2012 (5010ABB1)
fffff880`01600000 fffff880`0160a000   Fs_Rec   Fs_Rec.sys   Wed Jul 25 22:30:08 2012 (5010ABB0)
fffff880`02126000 fffff880`0219c000   fvevol   fvevol.sys   Thu Sep 20 02:08:15 2012 (505AB2CF)
fffff880`020a3000 fffff880`0210b000   fwpkclnt fwpkclnt.sys Thu Feb 28 23:55:54 2013 (513034DA)
fffff801`d680c000 fffff801`d6878000   hal      hal.dll      Tue Oct 23 23:03:21 2012 (50875A79)
fffff880`05e25000 fffff880`05e3b000   HDAudBus HDAudBus.sys Thu Sep 20 02:08:43 2012 (505AB2EB)
fffff880`050a9000 fffff880`05102000   HdAudio  HdAudio.sys  Tue Jun 25 22:59:33 2013 (51CA5915)
fffff880`05eca000 fffff880`05edd000   HECIx64  HECIx64.sys  Mon Jul 02 18:14:58 2012 (4FF21D62)
fffff880`05130000 fffff880`0514b000   HIDCLASS HIDCLASS.SYS Fri Jun 28 23:07:12 2013 (51CE4F60)
fffff880`0514b000 fffff880`05153000   HIDPARSE HIDPARSE.SYS Fri Jun 28 23:08:18 2013 (51CE4FA2)
fffff880`05123000 fffff880`05130000   hidusb   hidusb.sys   Sat May 04 00:48:26 2013 (5184931A)
fffff880`08692000 fffff880`08771000   HTTP     HTTP.sys     Thu Mar 14 20:17:15 2013 (5142688B)
fffff880`05f98000 fffff880`05fb8000   i8042prt i8042prt.sys Wed Jul 25 22:28:50 2012 (5010AB62)
fffff880`0163a000 fffff880`01904000   iaStorA  iaStorA.sys  Mon Jul 09 16:42:33 2012 (4FFB4239)
fffff880`05225000 fffff880`05241000   intelppm intelppm.sys Mon Nov 05 22:55:02 2012 (50988A16)
fffff880`05fb8000 fffff880`05fc7000   kbdclass kbdclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff801`d5b3a000 fffff801`d5b43000   kd       kd.dll       Wed Jul 25 22:30:34 2012 (5010ABCA)
fffff880`0422c000 fffff880`04237000   kdnic    kdnic.sys    Wed Jul 25 22:27:41 2012 (5010AB1D)
fffff880`04cf3000 fffff880`04d42000   ks       ks.sys       Sat Feb 02 02:25:50 2013 (510CBF7E)
fffff880`01200000 fffff880`0121b000   ksecdd   ksecdd.sys   Thu Sep 20 02:09:16 2012 (505AB30C)
fffff880`01d4a000 fffff880`01d79000   ksecpkg  ksecpkg.sys  Thu Oct 11 01:16:46 2012 (5076563E)
fffff880`05293000 fffff880`05298380   ksthunk  ksthunk.sys  Wed Jul 25 22:28:58 2012 (5010AB6A)
fffff880`05f7a000 fffff880`05f98000   L1C63x64 L1C63x64.sys Wed Feb 15 01:55:09 2012 (4F3B56CD)
fffff880`051a4000 fffff880`051b8000   lltdio   lltdio.sys   Wed Jul 25 22:24:02 2012 (5010AA42)
fffff880`0517c000 fffff880`051a4000   luafv    luafv.sys    Wed Jul 25 22:29:13 2012 (5010AB79)
fffff880`00c44000 fffff880`00ca3000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Wed Jul 25 22:30:12 2012 (5010ABB4)
fffff880`0516e000 fffff880`0517c000   monitor  monitor.sys  Thu Feb 28 23:56:18 2013 (513034F2)
fffff880`0515f000 fffff880`0516e000   mouclass mouclass.sys Wed Jul 25 22:28:47 2012 (5010AB5F)
fffff880`05153000 fffff880`0515f000   mouhid   mouhid.sys   Fri Mar 01 21:15:53 2013 (513160D9)
fffff880`0149f000 fffff880`014b9000   mountmgr mountmgr.sys Wed Jul 25 22:29:33 2012 (5010AB8D)
fffff880`08791000 fffff880`087a8000   mpsdrv   mpsdrv.sys   Thu Oct 11 01:15:15 2012 (507655E3)
fffff880`08600000 fffff880`08663000   mrxsmb   mrxsmb.sys   Tue Feb 05 17:29:08 2013 (511187B4)
fffff880`087a8000 fffff880`087f3000   mrxsmb10 mrxsmb10.sys Wed Jul 25 22:23:06 2012 (5010AA0A)
fffff880`05000000 fffff880`0503b000   mrxsmb20 mrxsmb20.sys Tue Feb 05 17:28:36 2013 (51118794)
fffff880`048d6000 fffff880`048e2000   Msfs     Msfs.SYS     Wed Jul 25 22:30:24 2012 (5010ABC0)
fffff880`00f1c000 fffff880`00f26000   msisadrv msisadrv.sys Wed Jul 25 22:28:02 2012 (5010AB32)
fffff880`090df000 fffff880`090f6000   mslldp   mslldp.sys   Wed Jul 25 22:23:53 2012 (5010AA39)
fffff880`01011000 fffff880`01074000   msrpc    msrpc.sys    Wed Jul 25 22:28:37 2012 (5010AB55)
fffff880`03e91000 fffff880`03e9d000   mssmbios mssmbios.sys Wed Jul 25 22:29:19 2012 (5010AB7F)
fffff880`01e3b000 fffff880`01e52000   mup      mup.sys      Wed Jul 25 22:30:00 2012 (5010ABA8)
fffff880`014b9000 fffff880`015b4000   ndis     ndis.sys     Sat Jun 15 01:11:35 2013 (51BBF787)
fffff880`03fee000 fffff880`03ffa000   ndistapi ndistapi.sys Thu Sep 20 02:09:19 2012 (505AB30F)
fffff880`04577000 fffff880`045a6000   ndiswan  ndiswan.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`04d4d000 fffff880`04d61000   NDProxy  NDProxy.SYS  Mon Apr 08 22:33:41 2013 (51637E05)
fffff880`0503b000 fffff880`05057000   Ndu      Ndu.sys      Wed Jul 25 22:23:41 2012 (5010AA2D)
fffff880`0462a000 fffff880`0463a000   netbios  netbios.sys  Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`04912000 fffff880`0496a000   netbt    netbt.sys    Wed Jul 25 22:24:26 2012 (5010AA5A)
fffff880`01cdb000 fffff880`01d4a000   NETIO    NETIO.SYS    Thu Oct 11 01:16:20 2012 (50765624)
fffff880`048c4000 fffff880`048d6000   Npfs     Npfs.SYS     Wed Jul 25 22:30:26 2012 (5010ABC2)
fffff880`046d5000 fffff880`046e1000   npsvctrig npsvctrig.sys Wed Jul 25 22:27:33 2012 (5010AB15)
fffff880`046c7000 fffff880`046d5000   nsiproxy nsiproxy.sys Wed Jul 25 22:25:00 2012 (5010AA7C)
fffff801`d6878000 fffff801`d6fc4000   nt       ntkrnlmp.exe Fri May 31 23:13:17 2013 (51A966CD)
fffff880`0121c000 fffff880`013ff000   Ntfs     Ntfs.sys     Sat Feb 02 02:25:09 2013 (510CBF55)
fffff880`03fa7000 fffff880`03fb0000   Null     Null.SYS     Wed Jul 25 22:30:16 2012 (5010ABB8)
fffff880`04600000 fffff880`0462a000   pacer    pacer.sys    Wed Jul 25 22:23:05 2012 (5010AA09)
fffff880`00e4c000 fffff880`00e66000   partmgr  partmgr.sys  Tue Jan 08 23:01:42 2013 (50ECEBA6)
fffff880`00f26000 fffff880`00f63000   pci      pci.sys      Wed Jul 25 22:27:43 2012 (5010AB1F)
fffff880`019e7000 fffff880`019f8000   pcw      pcw.sys      Wed Jul 25 22:28:44 2012 (5010AB5C)
fffff880`00e35000 fffff880`00e4c000   pdc      pdc.sys      Thu Feb 28 23:58:34 2013 (5130357A)
fffff880`08cad000 fffff880`08d79000   peauth   peauth.sys   Mon Apr 08 22:32:01 2013 (51637DA1)
fffff880`04ca4000 fffff880`04cef000   portcls  portcls.sys  Thu Oct 11 01:16:51 2012 (50765643)
fffff880`00d22000 fffff880`00d37000   PSHED    PSHED.dll    Thu Jul 26 00:53:53 2012 (5010CD61)
fffff880`0526c000 fffff880`05291000   rasl2tp  rasl2tp.sys  Wed Jul 25 22:23:16 2012 (5010AA14)
fffff880`01c94000 fffff880`01cae000   raspppoe raspppoe.sys Wed Jul 25 22:24:55 2012 (5010AA77)
fffff880`0524b000 fffff880`0526c000   raspptp  raspptp.sys  Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`045a6000 fffff880`045c4000   rassstp  rassstp.sys  Wed Jul 25 22:23:59 2012 (5010AA3F)
fffff880`0463a000 fffff880`046ad000   rdbss    rdbss.sys    Sat May 04 00:47:00 2013 (518492C4)
fffff880`04d42000 fffff880`04d4d000   rdpbus   rdpbus.sys   Wed Jul 25 22:28:19 2012 (5010AB43)
fffff880`01e00000 fffff880`01e3b000   rdyboost rdyboost.sys Wed Jul 25 22:28:34 2012 (5010AB52)
fffff880`051b8000 fffff880`051d0000   rspndr   rspndr.sys   Wed Jul 25 22:24:06 2012 (5010AA46)
fffff880`08d79000 fffff880`08d84000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`05218000 fffff880`05225000   serenum  serenum.sys  Wed Jul 25 22:30:13 2012 (5010ABB5)
fffff880`05200000 fffff880`05218000   serial   serial.sys   Wed Jul 25 22:30:01 2012 (5010ABA9)
fffff880`011ae000 fffff880`011f7000   spaceport spaceport.sys Sat May 04 00:48:43 2013 (5184932B)
fffff880`09052000 fffff880`090df000   srv      srv.sys      Wed Jul 25 22:25:28 2012 (5010AA98)
fffff880`08c00000 fffff880`08ca1000   srv2     srv2.sys     Mon Apr 08 22:33:02 2013 (51637DDE)
fffff880`08d84000 fffff880`08dc8000   srvnet   srvnet.sys   Mon Apr 08 22:31:13 2013 (51637D71)
fffff880`01904000 fffff880`01959000   storport storport.sys Thu Feb 28 23:58:51 2013 (5130358B)
fffff880`05291000 fffff880`05292480   swenum   swenum.sys   Wed Jul 25 22:28:53 2012 (5010AB65)
fffff880`01e6a000 fffff880`020a3000   tcpip    tcpip.sys    Thu Aug 01 04:17:52 2013 (51FA19B0)
fffff880`08dc8000 fffff880`08dda000   tcpipreg tcpipreg.sys Wed Jul 25 22:23:13 2012 (5010AA11)
fffff880`04904000 fffff880`04912000   TDI      TDI.SYS      Wed Jul 25 22:27:59 2012 (5010AB2F)
fffff880`048e2000 fffff880`04904000   tdx      tdx.sys      Wed Jul 25 22:24:58 2012 (5010AA7A)
fffff880`00cff000 fffff880`00d22000   tm       tm.sys       Wed Jul 25 22:29:01 2012 (5010AB6D)
fffff880`00e00000 fffff880`00e28000   tpm      tpm.sys      Thu Feb 28 23:56:34 2013 (51303502)
fffff960`007b0000 fffff960`007b9000   TSDDD    TSDDD.dll    Wed Jul 25 22:30:25 2012 (5010ABC1)
fffff880`04200000 fffff880`0422c000   tunnel   tunnel.sys   Wed Jul 25 22:23:04 2012 (5010AA08)
fffff880`05e92000 fffff880`05eca000   ucx01000 ucx01000.sys Mon Jul 01 18:15:15 2013 (51D1FF73)
fffff880`045dc000 fffff880`045ee000   umbus    umbus.sys    Wed Jul 25 22:27:39 2012 (5010AB1B)
fffff880`04c00000 fffff880`04c0b000   USBD     USBD.SYS     Fri Jun 28 23:08:18 2013 (51CE4FA2)
fffff880`05edd000 fffff880`05ef3000   usbehci  usbehci.sys  Fri Jun 28 23:07:25 2013 (51CE4F6D)
fffff880`04d61000 fffff880`04dfd000   usbhub   usbhub.sys   Fri Jun 28 23:06:58 2013 (51CE4F52)
fffff880`04c0b000 fffff880`04c7f000   UsbHub3  UsbHub3.sys  Fri Jun 28 23:05:16 2013 (51CE4EEC)
fffff880`05ef3000 fffff880`05f70000   USBPORT  USBPORT.SYS  Fri Jun 28 23:07:37 2013 (51CE4F79)
fffff880`05e3b000 fffff880`05e92000   USBXHCI  USBXHCI.SYS  Fri Jun 28 23:05:19 2013 (51CE4EEF)
fffff880`00e28000 fffff880`00e35000   vdrvroot vdrvroot.sys Wed Jul 25 22:27:29 2012 (5010AB11)
fffff880`01074000 fffff880`010ba000   VerifierExt VerifierExt.sys Wed Jul 25 22:28:18 2012 (5010AB42)
fffff880`00e66000 fffff880`00e7e000   volmgr   volmgr.sys   Wed Jul 25 22:29:22 2012 (5010AB82)
fffff880`0143f000 fffff880`0149f000   volmgrx  volmgrx.sys  unavailable (FFFFFFFE)
fffff880`0219c000 fffff880`021f0000   volsnap  volsnap.sys  Fri May 31 23:10:22 2013 (51A9661E)
fffff880`046ad000 fffff880`046c7000   wanarp   wanarp.sys   Mon Apr 08 22:31:00 2013 (51637D64)
fffff880`04854000 fffff880`04865000   watchdog watchdog.sys Wed Jul 25 22:29:05 2012 (5010AB71)
fffff880`010ba000 fffff880`0117c000   Wdf01000 Wdf01000.sys Fri Jun 21 23:13:05 2013 (51C51641)
fffff880`0117c000 fffff880`0118c000   WDFLDR   WDFLDR.SYS   Fri Jun 21 23:14:38 2013 (51C5169E)
fffff880`0210b000 fffff880`02126000   wfplwfs  wfplwfs.sys  Thu Jun 06 23:13:56 2013 (51B14FF4)
fffff960`00118000 fffff960`00508000   win32k   win32k.sys   Fri Aug 23 01:11:16 2013 (5216EEF4)
fffff880`05241000 fffff880`0524b000   wmiacpi  wmiacpi.sys  Wed Jul 25 22:29:53 2012 (5010ABA1)
fffff880`00f12000 fffff880`00f1c000   WMILIB   WMILIB.SYS   Wed Jul 25 22:30:04 2012 (5010ABAC)
fffff880`011a3000 fffff880`011ae000   WppRecorder WppRecorder.sys Wed Jul 25 22:29:07 2012 (5010AB73)
Unloaded modules:
fffff880`021f0000 fffff880`021fd000   dump_storport.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`04247000 fffff880`04511000   dump_iaStorA.sys
    Checksum:  00000000
    ImageSize:  002CA000
fffff880`04511000 fffff880`04525000   dump_dumpfve.sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`05f70000 fffff880`05f7a000   amdkmafd.sys
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`05e1b000 fffff880`05e25000   amdkmafd.sys
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`03eae000 fffff880`03ec0000   dam.sys
    Checksum:  00000000
    ImageSize:  00012000
fffff880`01e52000 fffff880`01e5e000   hwpolicy.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`00c37000 fffff880`00c44000   ApiSetSchema.dll
    Checksum:  00000000
    ImageSize:  0000D000
I would first completely remove your video drivers, then install a freshly downloaded copy of the latest, Win8 compatible drivers for your video card.
If that doesn't fix things, then I'd try the video stress tests from the hardware diagnostics that I posted earlier ( Hardware Diagnostics).
Good luck!
    Samsung/NP780
    800x600
Hello!
I've tried reinstalling my display driver multiple times, but with no success (as seen above). Could you please tell me exactly which driver should I download and how to actually delete the previous one completely? (I'm starting to doubt that I do it right, since it doesn't help at all.) I have a Sapphire HD 7770 GHz Edition. I hope it's not that big of a setback or problem, would help immensely.
Thank you in advance!
I presume that this is a Desktop system.
Run the Catalyst Uninstall Utility from here: Download
Then download the latest Catalyst Software Suite from here: Desktop
    Samsung/NP780
    800x600
I did everything, and now got a BSOD again, I include the files needed and also included the BlueScreenViewer file in case it is needed.
EDIT: just got another one with BlueScreenViewer saying that nothing went wrong, still bsod. I'm clueless.
Have you run the hardware diagnostics that I suggested? If not, please do so. Here's the link again: Hardware Diagnostics Please let us know the results of the tests.
These memory dumps seem to point to hardware, with the video card being the most likely suspect. Please run the hardware diagnostics that I suggested earlier and post back with the results here.
Analysis:
[font=lucida console]**************************Thu Oct 31 11:06:18.898 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103113-18765-01.dmp]
System Uptime:[B]0 days 1:01:56.574[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiTimerWaitTest+39f )[/B]
BugCheck [B]A, {80028, 2, 1, fffff80145704321}[/B]
Arguments:
Arg4: fffff80145704321, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nt!KiTimerWaitTest[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Thu Oct 31 09:41:37.935 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103113-15859-01.dmp]
System Uptime:[B]0 days 0:28:58.610[/B]
Probably caused by :[B]atikmdag.sys ( atikmdag+23c5c )[/B]
BugCheck [B]A0000001, {5, 0, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#Example]Unknown bugcheck code (a0000001)[/url]
Arguments:
Arg1: 0000000000000005
BUGCHECK_STR:  0xA0000001
FAILURE_BUCKET_ID: [B]0xA0000001_atikmdag+23c5c[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Oct 30 05:29:44.302 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103013-16171-01.dmp]
System Uptime:[B]0 days 0:12:27.025[/B]
Probably caused by :[B]atikmdag.sys ( atikmdag+37c1a )[/B]
BugCheck [B]C4, {2001c, fffff88001081090, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C4]DRIVER_VERIFIER_DETECTED_VIOLATION (c4)[/url]
Arguments:
FAILURE_BUCKET_ID: [B]0xc4_IrqlPsPassive_XDV_VRF_atikmdag+37c1a[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Oct 30 05:16:52.769 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103013-24187-01.dmp]
System Uptime:[B]0 days 1:05:06.491[/B]
BugCheck [B]C4, {2001c, fffff8800115f090, 0, 0}[/B]
Arguments:
Arg2: fffff8800115f090, A pointer to the string describing the violated rule condition.
PROCESS_NAME:  dwm.exe
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Oct 30 04:11:20.979 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103013-17500-01.dmp]
System Uptime:[B]0 days 0:31:36.701[/B]
BugCheck [B]C4, {2001c, fffff880010da090, 0, 0}[/B]
Arguments:
Arg2: fffff880010da090, A pointer to the string describing the violated rule condition.
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Oct 30 03:39:19.511 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103013-17250-01.dmp]
System Uptime:[B]0 days 0:31:38.233[/B]
BugCheck [B]C4, {2001c, fffff88001026090, 0, 0}[/B]
Arguments:
Arg2: fffff88001026090, A pointer to the string describing the violated rule condition.
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Oct 30 03:07:17.715 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103013-19218-01.dmp]
System Uptime:[B]0 days 0:12:42.439[/B]
BugCheck [B]C4, {2001c, fffff88001149090, 0, 0}[/B]
Arguments:
Arg2: fffff88001149090, A pointer to the string describing the violated rule condition.
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Oct 30 02:54:06.779 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\103013-25656-01.dmp]
System Uptime:[B]0 days 0:42:05.503[/B]
BugCheck [B]C4, {2001c, fffff880010d8090, 0, 0}[/B]
Arguments:
Arg2: fffff880010d8090, A pointer to the string describing the violated rule condition.
MaxSpeed:     3300
  BIOS Version                  1103
**************************Tue Oct 29 14:59:13.576 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102913-20984-01.dmp]
System Uptime:[B]0 days 4:05:49.253[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b4 )[/B]
BugCheck [B]7F, {8, fffff8001b0d3e70, 10a70, fffff80019be9771}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000007F]UNEXPECTED_KERNEL_MODE_TRAP (7f)[/url]
Arguments:
Arg1: 0000000000000008, EXCEPTION_DOUBLE_FAULT
Arg2: fffff8001b0d3e70
Arg3: 0000000000010a70
Arg4: fffff80019be9771
BUGCHECK_STR:  0x7f_8
FAILURE_BUCKET_ID: [B]0x7f_8_nt!KiDoubleFaultAbort[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Tue Oct 29 10:52:55.868 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102913-15937-01.dmp]
System Uptime:[B]0 days 1:15:25.544[/B]
Probably caused by :[B]Ntfs.sys ( Ntfs!NtfsCommonRead+1b6e )[/B]
BugCheck [B]24, {b50019060b, fffff8800afe8cc8, fffff8800afe8500, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000024]NTFS_FILE_SYSTEM (24)[/url]
Arguments:
Arg1: 000000b50019060b
Arg2: fffff8800afe8cc8
Arg3: fffff8800afe8500
PROCESS_NAME:  Wow-64.exe
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]0x24_NULL_IP_Ntfs!NtfsCommonRead[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Mon Oct 28 10:11:37.683 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102813-21734-02.dmp]
System Uptime:[B]0 days 0:49:17.359[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CcGetVirtualAddress+24f )[/B]
BugCheck [B]3B, {c0000005, fffff8031aabca0f, fffff88008205a20, 0}[/B]
Arguments:
Arg2: fffff8031aabca0f, Address of the instruction which caused the bugcheck
Arg3: fffff88008205a20, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]0x3B_nt!CcGetVirtualAddress[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Mon Oct 28 09:21:48.079 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102813-21734-01.dmp]
System Uptime:[B]0 days 11:48:25.785[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!SeOpenObjectAuditAlarmWithTransaction+1a8 )[/B]
BugCheck [B]50, {fffff8800cbac3f0, 0, fffff8009bcbd463, 2}[/B]
Arguments:
Arg1: fffff8800cbac3f0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff8009bcbd463, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  AV
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]AV_nt!SeOpenObjectAuditAlarmWithTransaction[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Sun Oct 27 21:32:51.227 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\102813-20703-01.dmp]
System Uptime:[B]0 days 0:47:15.903[/B]
Probably caused by :[B]hardware ( win32k!EngAcquireSemaphore+a0a8 )[/B]
BugCheck [B]3B, {c0000005, fffff8022e2bcb6c, fffff88006b30e00, 0}[/B]
Arguments:
Arg2: fffff8022e2bcb6c, Address of the instruction which caused the bugcheck
Arg3: fffff88006b30e00, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]IP_MISALIGNED[/B]
MaxSpeed:     3300
  BIOS Version                  1103
Arguments:
BUGCHECK_STR:  0x3B
MaxSpeed:     3300
  BIOS Version                  1103
[/font]
3rd Party Drivers:
atikmpag.sys                Tue Oct  8 08:27:46 2013 (5253FA42)
atikmdag.sys                Tue Oct  8 09:51:03 2013 (52540DC7)
eamonm.sys                  Tue Feb  5 03:23:32 2013 (5110C184)
[/font]
http://www.carrona.org/drivers/driver.php?id=epfwwfpr.sys
http://www.carrona.org/drivers/driver.php?id=ehdrv.sys
http://www.carrona.org/drivers/driver.php?id=eamonm.sys
    Samsung/NP780
    800x600
I ran memtest, hddiag and furmark. Neither of them showed any errors. I printscreened the state which furmark stabilized in. I ran it 3 times for about half an hour and every time it was exactly the same.
Have you run Prime95; the other video tests (and the PSU test in the OCCT test) and the CPU tests?
If so, what were the results?
    Samsung/NP780
    800x600
I ran the video tests (vmt and memtestCL). MemtestCL showed no errors, as well as vmt twice, but one time it showed something different, I include the result file. I ran the intel diagnostic tool, it showed no errors too, I ran Prime95 today, everything went fine until about 4 hours of runtime, when the computer crashed with the IRQL_NOT_LESS_OR_EQUAL, not sure if it was because Prime95 or because I had to use the computer for a while. (I ran it in Small FFTs, since my comp already passed memtest86, although I can run it in blend overnight, but I can't monitor it that way).
EDIT: I got a new one, might be interesting for you, I don't know.
EDIT2: Seeing from what is happening, the computer crashes most frequently when I open World of Warcraft, it is just a wild guess, but that's what I observed from the past 2-3 days.
As you've updated your video drivers and the only signs of issues are video, I'd have to suggest trying another video card.
If you don't have one on hand to try, then I'd purchase one that you can return (in case it's not needed).
Don't forget to remove the drivers for the old card, and install fresh, new drivers that are compatible with the OS.
Good Luck!
    Samsung/NP780
    800x600
Hello!
I changed my graphics card to my older one, (Sapphire Radeon HD3850) and once again I got BSOD-s. I included the files necessary. I've used that card for a good 2 year and it worked perfectly.
All 3 memory dumps say "hardware". If we presume that the old video card is good, then the only thing left is the motherboard.
Do you have other slots that you can try for a graphics card? If not, then we're looking at trying a new motherboard (this presumes that you've done all of the hardware tests - to include the CPU stress tests).
I did notice that the XBox controller is still installed. While not a likely cause at this point, we must rule out all possibilities before coming to the conclusion that it's the motherboard (and then going through the cost and pain of installing another motherboard).
[FONT=lucida console]**************************Sat Nov  9 15:33:22.763 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110913-35250-01.dmp]
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Built by: [B]9600[/B].16404.amd64fre.winblue_gdr.130913-2141
System Uptime:[B]1 days 11:09:43.452[/B]
Probably caused by :[B]hardware ( nt!RtlpGetStackLimits+b4 )[/B]
BugCheck [B]50, {ffffffffffffffc0, 1, fffff802e28e91a0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000050"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: ffffffffffffffc0, memory referenced.
Arg3: fffff802e28e91a0, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  AV
MaxSpeed:     3300
  BIOS Version                  1103
**************************Wed Nov  6 01:20:02.195 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110613-15718-01.dmp]
System Uptime:[B]0 days 7:47:05.884[/B]
Probably caused by :[B]hardware ( atikmdag+b84ea )[/B]
BugCheck [B]D1, {100, 2, 1, fffff8000214b4ea}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000000100, memory referenced
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff8000214b4ea, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]IP_MISALIGNED_atikmdag.sys[/B]
MaxSpeed:     3300
  BIOS Version                  1103
**************************Tue Nov  5 16:50:15.088 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\110513-24421-01.dmp]
System Uptime:[B]0 days 3:45:28.778[/B]
*** ERROR: Module load completed but symbols could not be loaded for intelppm.sys
Probably caused by :[B]hardware ( intelppm+11f8 )[/B]
BugCheck [B]50, {ffffffffffffff84, 1, fffff80001f5f1f8, 0}[/B]
Arguments:
Arg1: ffffffffffffff84, memory referenced.
Arg3: fffff80001f5f1f8, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]IP_MISALIGNED_intelppm.sys[/B]
MaxSpeed:     3300
  BIOS Version                  1103
[/FONT]
3rd Party Drivers:
atikmpag.sys                Mon Jun 18 16:41:29 2012 (4FDF9279)
atikmdag.sys                Mon Jun 18 17:21:01 2012 (4FDF9BBD)
L1C63x64.sys                Wed Jun 26 03:26:34 2013 (51CA97AA)
TeeDriverx64.sys            Tue Jul  2 14:38:08 2013 (51D31E10)
dump_iaStorA.sys            Thu Aug  1 21:39:52 2013 (51FB0DE8)
intelppm.sys                Thu Aug 22 04:46:35 2013 (5215CFEB)
xusb22.sys                  Thu Aug 22 07:38:23 2013 (5215F82F)
AtihdWB6.sys                Sat Jun 22 22:19:48 2013 (51C65B44)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=TeeDriverx64.sys
AtihdWB6.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
    Samsung/NP780
    800x600
