VivoTAB Smart LTE problem after 8.1
    VivoTAB Smart LTE and problem after inst 8.1
    Hello everyone.
    After installing Windows 8.1 I have a problem with the wake-up device.
    My tablet goes to sleep, when I wake it up I have to wait a few seconds until the display driver will respond.
    Log Name: System
    Source: Display
    Date: 2013-10-19 11:45:29 p.m.
    Event ID: 4101
    Task Category: None
    Level: Warnings
    Keywords: Classic
    User: Not applicable
    Computer: MyComputerName
    Igdkmd32 Display driver stopped responding and has recovered.
    Problem occurs every time when computer goes to sleep and i had to wake it up.
    Do you have any ideas?
    Hi, I have exactly the same problem, there is apparently no update driver available for the moment. If the problem persists in the next days/weeks we may have to restore windows 8.0 ...
Asus smart gesture install problem
(I'm not english, I'm sorry if I making some grammar mistakes) I have a 32 bit asus k55vd laptop. Lately my smart gesture begon to slowing down. I had found a newer version of it so i wanted to uninstall mine and install the new one. Now can't i install the new one. First I needed to install...
cannot reset factory my asus vivotab smart me400c
hello I installed windows 8.1 in clean mode . now I want to reset to factory default but I have not backuped media. but I have recovery partition but I can not build recovery disk because when I use"create recovery drive" wizard I can not select " copy the recovery partition from the pc to the...
Drivers & Hardware
How do I install programs to my VivoTab Smart?
Title says it all. I have some programs (on my PC) that I would like to install somehow onto my vivotab. I am not super programmer literate so simple terms are best. I plugged my tablet into my PC to try to just drag the program over (apparently that is a no go). I even got so far as to drag it...
Drivers & Hardware
System Refresh & Image Recovery problem on Asus Vivotab
I have made a System Image & a Custom Recovery Image on my Asus Vivotab but I cannot get the system to recognize them on a USB Hard Drive. I got into this by testing the Refresh Custom Recovery Image. The system did not find the image as the system allocated a different drive letter so I have...
Drivers & Hardware
Bluetooth keyboard problem on Asus Vivotab
My bt keyboard connects fine but it doesn't stay connected. I go into pc options to reconnect but cannot. I tap the icon and nothing happens. I can only reconnect if I remove the device and start from scratch to rediscover it and connect. I saw advice to go into Device Manager and uncheck 'allow...
Drivers & Hardware
Asus VivoTab Smart - restore recovery partition?
My tablet is running fine, but I did something (not bright) which could leave me in a lurch later. Here's what I did, and what I'm looking for. Soon after I purchased my Asus VivoTab Smart, I made a USB recovery disk, complete with recovery partition. Then, to save disk space on the tablet, I...
Drivers & Hardware
Asus' VivoTab Smart ME400C tablet reviewed
a very thorough review of the Asus VivoTab Smart ME400C at TechReport. Lots of good info so if you're interested in a budge tablet, check it out: http:// only excerpts (refer to full article): 21216 Today, the...
Drivers & Hardware
